DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
How to hook up a MBC
Old Aug 23, 2007 | 04:36 PM
  #71
cincyTT's Avatar
I'm make believe
Default RE: How to hook up a MBC
Yes, you need a 4.3v diode. You need to limit the boost reading to under 14.7psi. Also, post these ?'s in the correct thread (see sig).
Old Oct 6, 2007 | 08:23 AM
  #72
Volcom's Avatar
Hey guys first post on here Ok i got my self a MBC this one but i got a (Autotecnica one)http://img248.imageshack.us/img248/9...dboost3nx8.jpganywyas I installed with the N75 all hooked up, getting heaps of boost it will hit 20psi and cut of for a second and i just cant get it to run below 15psi or anywhere below!!! i tried swaping the hoses from the inlet to out let still same problem? Why could this be? Even when i totaly close the MBC it still boost at 20psi
PS: I got a chip in my car
Thanks for any help
I just noticed that 1st and 2nd at 17psi dont do any cut offs it it's only 3rd 4th and 5th gear that will cut out and it seems that in 3rd 4th 5th it hits 18psi!?
Old Oct 6, 2007 | 02:19 PM
  #73
Audi_Skydiver's Avatar
i have that one as well (except mine is blue) and I am having problems with it as well. My boost jumps all over the place 10-22PSI so it's not smooth by any means. I am going to go back to using the N75 to see if that works better for me today. (Have not tried that since I got my K04 setup). Hopefully It works. It's really annoying trying to drive like that.
Josh
Old Oct 6, 2007 | 08:04 PM
  #74
Volcom's Avatar
Mine is sweet it wont flactuate at all but i just cant adjust? I just cant get lower boost levels?
Old Oct 8, 2007 | 10:11 PM
  #75
Volcom's Avatar
Ok i sused out my problem was a melted vacum line Anyways all fixed now My question is when i have turned the MBC to the lowest settings in first gear i get 11PSI thats what my chip gives me and soon as i hit 2nd gear it will go all the way to 17psi and stay there how is this? If i had no MBC installed i would of only goten about 12-13psi? why is it giving extra 5-6Psi?
Old Oct 8, 2007 | 10:14 PM
  #76
cincyTT's Avatar
I'm make believe
you wont get the same psi in first and usually second due to load and gearing
Old Oct 10, 2007 | 11:03 AM
  #77
rafa_207's Avatar
I have an APR chip on my car and I just to run 20psi now Im only running 15psi and I dont have no boost leaks do you guys think I can solve my problem by installing mbc and is it safe for the engine and turbo to run one of these and what is the best way to install them ...
Old Oct 10, 2007 | 04:52 PM
  #78
cincyTT's Avatar
I'm make believe
if you just installed that fmic and lost 5psi, thats not very good. You sure your usuing 2.25" piping? 0-3psi drop is expected for a normal kit depending on piping and size of the core.
But turning the boost up will be fine. Just remember that you have a drop and the turbo is running much more boost than your engine/boostgauge is seeing
Old Oct 10, 2007 | 10:28 PM
  #79
rafa_207's Avatar
no the problem started long before I installed the fmic
Old Oct 14, 2007 | 09:32 PM
  #80
Ericp501's Avatar
In cab MBC.. yay or nay?
