Crazy Radio
Old Mar 16, 2006 | 03:19 AM
rezurxtion's Avatar
Default Crazy Radio
Don't know if anyone has experienced this but I hooked up my amp and sub and noticed that when I took the keys out of the ignition and pushed the radio, it came on. I never tried this before the install so I do not know if it was a pre-existing condition. All I know is that it can't be good. If I turn the ignition off the radio turns off like normal. If you touch the radio with the key out, then it comes to life again???? Any help would be greatly appreciated. Thanks.
Old Mar 16, 2006 | 09:34 PM
gvvt's Avatar
Default RE: Crazy Radio
IIRC -- a big IF -- that's a feature. For some predefined length of time after you turn off the ignition, the radio will still turn on. 20 seconds? A minute?
Old Mar 16, 2006 | 10:46 PM
mddowlan's Avatar
I believe that this is perfectly normal. I noticed it the other day also. I don't know how long it stays on, or if it has a timer at all. It is at least 10 min because I made it through a couple songs.
I think that I'll check out the wondows/sunroof to see if they operate without the ignition on....
Old Apr 2, 2006 | 07:59 PM
pootey's Avatar
I though the same thing when that first happend in my car, But i had it on for over an hour the other day like that and it didn't turn off or even seem like it had a timer.
Old Apr 4, 2006 | 05:08 PM
kpatz's Avatar
The manual for the Symphony radio in my '02 A4 says the radio will run for up to 1 hour with the ignition off.
I guess this is Audi's answer to not having an "accessory" position on the ignition key to play the radio without turning on the ignition.
Old Jun 12, 2006 | 06:08 AM
bud15637's Avatar
is it a factory radio if so its ok it is ment to do that
Old Jun 12, 2006 | 04:11 PM
VitaminB6's Avatar
Yes, this is normal and expected. The radio will operate if the car is unlocked - avoids the need to leave the keys in if all you want to do is have some tunes when you're hanging out.
Marine702
Jan 27, 2013 07:10 PM
Starvagabond
Sep 6, 2012 07:14 PM
Porsche2AudiHappy
Feb 13, 2008 10:42 AM
jessiec132
Sep 3, 2007 11:22 AM
rezurxtion
Mar 16, 2006 01:14 PM
