WTS - Audi S4 Engine jumped timing
Well, I found a very nice used engine on eBay with the K04 upgrade already done, including a tuned ECU, so I'm selling my entire engine.
2000.5 B5 S4 2.7T. It has just under 160k on the odometer, the timing belt was done (previous owner) way back at the 60k mark but never again. The engine ran great, I had replaced the oil pressure sending unit and some other misc sensors over the last 4 years I've owned it, turbos were rebuilt at 120k (previous owner), I've had it since 140k, only put 20,000 miles on it in 4 years. It was a fun weekend driver for me.
Last October I was zipping down the interstate doing a lively 120, let off the accelerator going up a hill since I was getting off at the next exit, just coasting, up the crest of the hill, down the other side, and just as my exit was coming up, bucking and heaving engine, dump the clutch, coast down, starter won't turn the engine over.
Have it towed home, pull the front end, but couldn't turn the crank with the timing belt attached (still snug on the tensioner). I pull the timing belt and now I can turn the engine over by hand, but clearly interfering slightly with the valves as each one goes past the intake valve.
I haven't pulled it apart any further. For sale as it sits, good K03 stock turbos with 35-40k ish miles on them at the very least, wire harness, all the bolt-ons still attached. Would make a good candidate for rebuilding the heads and fixing your blown motor car or a rebuild base for upgrading.
Asking $750 obo plus shipping on your dime. I can strap it to a pallet and take it to a freight terminal. That's basically what I'd ask for the turbos plus $400 bucks for an entire engine that probably just needs the heads rebuilt. Pay my asking price and I'll also include two ECU's, one with a stock tune, one with a Stage 1 tune, GIAC copy with a slightly more aggressive low end, it ran VERY well. Paid $300 for the tuned ECU and a stock ECU goes for about that on eBay, so you're essentially getting a free engine with this sale.
Local shop in Nashville quoted me $300 to rebuild the heads and replace the valves that are bent (he was very familiar with which ones interfered). If you want to pay $1,100, I'll ship it to you with the heads rebuilt and back on it (I already have the gaskets).
I don't want to go to the trouble of pulling it all apart and then selling pieces individually at the moment.
Thanks,
Thanks,
