1999 A6 question
Old Jan 19, 2007 | 03:04 PM
foorausfoora's Avatar
Default 1999 A6 question
Where is the transimission dipstick on my 1999 audi 2.8 a6 quattro. how can i check my fluids ?
Old Jan 19, 2007 | 03:12 PM
2k S4's Avatar
Default RE: 1999 A6 question
There isn't one. To check manual trans, you jack up on a level surface, remove the fill plug & insert finger. It should be at or just below the filler.
On a slush box, warm up car, jack up level surface, start car, put threw all gears, let car idle in gear (yes tires will move) remove fill plug, if no fluid comes out,
put in fluid till it does, your full.
If you are worried about the trans, you might as well change the fluid while your in there.
Tlag
Feb 21, 2010 03:04 PM
tbird236
Oct 26, 2007 04:53 PM
honda16kelly
Jul 8, 2007 12:53 AM
Ed1955
Jan 31, 2006 12:17 AM
kidwissues97
May 13, 2005 03:24 AM
