2.7t sudden loss of power
Old 08-05-2011, 10:01 AM
Rafx003's Avatar
Default 2.7t sudden loss of power
Hi guys!
I got an Allroad 2003 2.7t with 120k miles
Recently after pulling from a stop sign the engine lost power and went dead.
On restart it revs up a bit and shuts down immediately unless I keep it above 3000 rpm
Timing belt done 40k ago and torque conv/valve body done 25k ago.
Any help highly appreciated!
Old 08-05-2011, 10:32 AM
02A6Beau's Avatar
initial thoughts..
fuel pump? fuel filter?
CEL?
fuel+air+spark=run sounds like you have spark, so either a fuel problem or an air problem
really need to hook it up to a reader and pull codes.
Old 08-05-2011, 11:01 AM
Rafx003's Avatar
Yep, I got CEL on, will try to read it later today
My first thought was the timing belt skipped a tooth but if that happens engine won't run, right?
Old 08-05-2011, 01:19 PM
02A6Beau's Avatar
1/2 to 1 tooth off will either advance, or retard the timing by a little bit which could cause your problems. Since it has been 40K miles on your current timing belt without this issue I would be skeptical of that occurring. Your timing belt has some pretty aggressive "teeth" and there is really no way for it to skip (improbable but not impossible). You may have a problem with the camshaft position sensor. A scan should tell you if that is the problem.
good luck
-not an expert, just an enthusiast
Old 08-05-2011, 07:39 PM
Rafx003's Avatar
Codes read:
P2018
P0421
P0310
P0301
P0305
P0304
P0303
Cause:
Main air supply manifold just behind air filter box had a 0.5 inch gap at the bottom, refitted, reset CEL, runes like new.
Thanks !
Old 08-05-2011, 11:19 PM
02A6Beau's Avatar
Awesome. glad you go it sorted.
RMatthew
06-24-2013 10:44 AM
torque27
11-16-2010 07:25 AM
HorchA3
10-27-2010 02:15 AM
nmoore
09-05-2007 07:48 PM
KSpark
02-13-2007 08:52 PM
Quick Reply: 2.7t sudden loss of power
