200 question.
Old Jan 16, 2007 | 12:04 AM
neoncrazy101's Avatar
Default 200 question.
Ok well my friend has an old Audi 200 non Quattro with 166,000 miles on it. and the red and yellow light in the middle of dash just stays on. we've checked everything else that the owners manual saids that they stand for and i'm just wondering if theres any way of either re-setting the PCM (if there is one on these older Audi's) or what else should we check to try and make them go off.
Old Jan 16, 2007 | 12:59 AM
Ninam's Avatar
Default RE: 200 question.
Doesn'tshow what the light's for?!
Old Jan 16, 2007 | 01:17 AM
sry... ok the red light thats moving is for oil and brake related stuff and the yellow one (its a circle) is for like the engine coolant, wiper fluid, battery voltage and such, and some other fluids (i forget the other ones sry). I might have those colors backwards but i'm pretty sure those are it. and sry i'm not too firmiliar with Audi's, since i'm more of a domestic person.
Old Jan 18, 2007 | 04:33 PM
so nobody knows? if u can reset those lights.
Old Jan 19, 2007 | 01:13 AM
kakarot's Avatar
you dont reset them, you fix them.
ether problem is real, or sensor is bad. thats usually the case.
Old Jan 19, 2007 | 01:31 AM
TommyL's Avatar
Or you pull them out, but thats not good idea
Old Jan 19, 2007 | 03:22 PM
2k S4's Avatar
I know this sounds dumb, but have you checked what the lights are telling you?
That might be the first time, or find out why they are all on in the first place. It might be as simple as ground that came loose,
of it might mean that you have a wiring short.
If it's a computer thing, you can try to unhook the battery for a while, to reset it. The other lights like the low coolant & low washer fluid are simple
sensors. They will not be reset until you fill the fluids, or short the sensors. Since they are all on, either you have a broke down car, or a real wiring problem.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
