2002 Audi A6 3.0L Hard Start Issue- Can't Figure Out Help!
Old Mar 30, 2018 | 09:49 PM
ltom76's Avatar
Default 2002 Audi A6 3.0L Hard Start Issue- Can't Figure Out Help!
My car starts easily in the morning when it is cold. The issue is after I drive the car and park it for 5 minutes or more, it will be a hard start. It will takes about 5 seconds of cranking before the car turns over and starts. After the car starts, if I turn it off, and start it again, it will crank over and start immediately. I tried all the following with no avail. Any ideas or advice?
• Replaced fuel filter
• Replaced fuel pressure regulator
• Replaced crankshaft engine speed sensor
• Replaced coolant temperature sensor
• Cleaned MAF sensor
• Replaced PVC valve
• Mechanic tested fuel pressure and says it is OK
• Coolant reservoir does leak drip out of bottom after driving awhile
• Occasional check engine codes P0421 (Warm Up Catalyst Efficiency Below Threshold (Bank 1) and P0431(Warm Up Catalyst Efficiency Below Threshold (Bank 2)) but passed smog emission test recently
ltom76
Sep 12, 2017 03:12 AM
Jérémy Rometti Hartman
May 5, 2013 06:46 PM
Armenian
Oct 25, 2011 06:53 PM
Jays TT
Jul 8, 2007 10:29 PM
dudley doright
Jul 16, 2006 04:06 AM
