2004 Audi A4 Quattro 1.8T Model B6
Old 02-14-2016, 11:41 PM
AudiVozza's Avatar
Default 2004 Audi A4 Quattro 1.8T Model B6
have a couple of questions as far as the coolant and head gasket. So when I started the car and drove it home it was smoking a fair amount, when I got home it had dissipated. I popped the hood and noticed that the car was sucking in coolant when the engine was running but when I turned it off it would fill right back up. A lot of people have told me it was a head gasket cause of the smoke but I've heard a number of different things. if you have anymore questions please just let me know so I can lay it all out for you. Thanks guys hope we can figure this out.
Old 02-15-2016, 10:01 AM
evans katongo's Avatar
I have an issue with AUDI A4,2003 model,it has low power,when i put the accelerator down to the bottom,revs are going up but i can not get a corresponding power,diagnostic has shown lean mixture,we have change plugs,changed coils but no improvement.At one point i discovered that the diaphragm in the PCB is broken,bought another one and its also broken.What am i missing in my trouble shooting?
Old 02-15-2016, 10:06 AM
For the coolant rushing back,there is possible restriction in the flow of coolant,i had that problem once with 2003 1.8T,i checked the thermostat,discovered it was faulty was broken and a broken piece was causing the brokage.Changed it and was all fine again
Old 02-15-2016, 10:07 AM
dave944's Avatar
If the smoke from the exhaust has an antifreeze smell, it is definitely letting coolant into the combustion chamber somehow. Leaking head gaskets are prime suspects.
siufailam
01-24-2012 07:56 AM
harm
10-09-2010 06:37 PM
audinor
05-05-2008 11:42 AM
zinbiel
02-17-2005 11:34 PM
Quick Reply: 2004 Audi A4 Quattro 1.8T Model B6
