A4 stalled and wont start
Old Nov 22, 2012 | 07:54 AM
zrsteve's Avatar
Default A4 stalled and wont start
98 A4 quattro 1.8T violent stall will not start getting plenty of gas the timing belt is fine the marks are all lined up checked all fuses turn's over wont fire.
thanks hope you can help
Old Nov 22, 2012 | 02:37 PM
z28pete's Avatar
Have you checked for spark?
Old Nov 22, 2012 | 06:25 PM
zrsteve's Avatar
Yes its firing. have any other suggestions? Thanks
Old Nov 27, 2012 | 12:23 AM
3star2nr's Avatar
Start with a very simple test, check that the coils are in the correct cylinders
Also you may need to check that the crank position sensor was set properly.
you can aalso try the following tests:
Return to basics, all cars are essentially the same. Spark, Air and fuel. Check things in that order. The fuel system is usually the most reliable part of a cars engine.
1. Faulty installed sensors: Check that all your sensors are properly plugged in
2. Check that the TPS and crank angle and cam angle sensors are properly installed
3. Vacuum Leak, check the EGR, PCV valve etc
4. Spark related: Your car doesnt use a distributor, so the only logical ignition problem has to be in the coil packs, spark plugs or the ignition amplifier or PTU I dont know what they call it on audis but its usually a seperate controller that takes the signal from the ecu and sends it to the coils, the coils then fire.
5. Improperly installed or fouled Spark plugs: Check your plug gaps, a gap two wide will cause missfiring, but it should occur at all times, if its a plug issue
6. Fuel issue (this is unlikely)
Good luck friend
Old Nov 27, 2012 | 02:27 AM
3star2nr's Avatar
Hints and Tips : Audi idle speed problems
Check that site out it might help you
Huntersirg
May 7, 2011 10:31 PM
MartinCieslak1
Nov 17, 2010 05:53 PM
carbonOX
Oct 23, 2009 02:09 AM
carbonOX
Oct 19, 2009 05:02 PM
