Any ideas?
Old Apr 12, 2006 | 08:31 AM
cap11n's Avatar
Default Any ideas?
I have a 2000 tt 225 and the engine management light has been on fo a while, am worried about taking it in to the garage incase I get ripped off (home improvements sucking my money dry, you know how it is). It seems to have lost a bit of power but otherwise runs fine. Sometimes when I turn it on the rev counter will bounce up and down and you can hear the engine noise going up and down as well.
My friend has a golf 4 motion and he said his did the same for a while and was something to do with the air flow to the turbo.
Anyone had the same problem?
Old Apr 12, 2006 | 08:32 AM
BadLuckAudi's Avatar
Default RE: Any ideas?
Check for vac leaks, probably have one and causing your motor to do wierd ****
Old Apr 12, 2006 | 08:37 AM
cap11n's Avatar
Forgive my ignorance......whats a vac leak?
Old Apr 12, 2006 | 03:27 PM
Beer Mod's Avatar
A vacuum leak is a leak that draws un-metered air into the motor and will cause the idle to fluctuate up and down.
B6A4Ohio
Feb 10, 2011 04:22 AM
B6A4Ohio
Nov 26, 2010 05:26 PM
Crekuc
Nov 3, 2008 09:59 PM
chefnic26
May 30, 2007 10:54 PM
shkenned
May 21, 2007 11:58 PM
