ATF info
Somebody used Castrol Imports MultiVehicle ATF?
An update- Castrol specifications:
good for:
AUDI - G-055-025-A2 (what is this?)
BMW - LT71141
Currently AUDI (for more than 10 years) is using LT71141 (VW G-052-162-A2)
(ZF transmissions 5HP19FLA (and many more) require --- LT71141)
AUDI (VW) and BMW are using the same ZF transmissions.
Based on that fact one could conclude that the ATF should be the same?
Any comments?
good for:
BMW - LT71141
Any comments?
OK, I got the Castrol info off of their site at: https://www.audiforums.com/fb.asp?m=698164. Did you go with Castrol or with Audi ATF? I am refilling a TT. They are selling the ATF from Audi at $30 a liter after quoting over the phone for $25.50. Either way it seems way too high for ATF fluid. Did you load the Castrol?
I used Castrol.
Drained the fluid.
Dropped the pan.
replaced the filter.
Assembled.
Refill (gravity, very time consuming). Suggest have a suction gun and pump in the till level. Then level at the correct temperature by gravity fill.
Used about 6 l.
Drained the fluid.
Dropped the pan.
Assembled.
Used about 6 l.
