Audi A3 and engine management problems?
Old Jul 6, 2015 | 03:11 AM
autonumenbella's Avatar
Default Audi A3 and engine management problems?
ive had an audi a3 for 11 months now, its 5 years old, low mileage. this year ive taken it into the garage 5 times with engine management problems. Anyone else own an audi and have had similar problems? its costing me a fortune! im so put off buying another audi.
The problem with dealerships is that they employ wannabe mechanics.
They think that you plug your car into a laptop, it tells you what's wrong and you change that part.
Dealerships will charge about £60 per hour for EVG7 DL46 tablet PC.
If you can find a decent garage they will read the error code from your ecu and then try to find out what is the true fault.
This will cost about £35 per hour.
5 times in 11 months is not good.
Have you any information on what the problems have been?
Audi's are a very reliable car on the whole,it sounds like the garage is not up to the job!
Old Jul 6, 2015 | 07:13 AM
dave944's Avatar
We don't call the Dealerships "Stealerships" over here for nothing. You can buy an OBD code reader and read the OBD codes on your own car for under $50US. However, I bought a more advanced unit that will do more than just report the fault codes.
What kind of specific problems are you having? Sometimes simple issues like a small vacuum leak or bad O2 sensor can cause a multitude of small problems that trip the Check Engine light. Simply throwing parts at the reported code will never fix it.
timboinva
May 2, 2012 01:01 PM
alex1
Apr 23, 2012 02:02 PM
DarrenN
Apr 30, 2011 10:43 AM
hmonay
B7 Models
Jun 5, 2009 02:58 PM
chrissyb
Feb 15, 2006 12:18 AM
