Audi A8 Heater isnt working
Old Dec 30, 2007 | 12:41 PM
pdx1bas's Avatar
Default Audi A8 Heater isnt working
I am looking at buying a 1997 A8 Quattro. During the test drive i noticed that although the engine temp warmed up to normal operating temp, the heat didnt work at all. The car came from southern california and the dealer told me it is probably because the heat function on the car had probably never even used due to the average temp being 80 degrees so the valve is stuck or bad that lets the hot coolant into the heater core... Can anyone help me diagnos this problem before i buy the car... Other than that the car is in fantastic shape with only 100k miles. thanks
Brian
Old Jan 1, 2008 | 12:14 PM
dankhound's Avatar
Default RE: Audi A8 Heater isnt working
First thing i would do is check the heater hoses. Make sure they are both getting hot. If they are you may have some sort of electrical problem with the system. Otherwise there is a cooling system issue.
vagman
Feb 8, 2015 03:05 PM
Iniquite
Nov 24, 2010 03:53 PM
ram
Jan 30, 2007 07:02 PM
mikefenge
Mar 1, 2006 11:22 AM
gregp1962
Nov 26, 2004 02:46 PM
