Breaks
Old May 22, 2017 | 04:48 AM
spikkeman's Avatar
Default Breaks
I have a 2002 Audi Allroad the front brakes overheated and seem to be applying pressure on the rotors without touching the brake peddle, I had to pull off the road and let the car sit for awhile and let them cool down .after they cooled I got the car home after driving around 5 miles, the front breaks seem to be hot again, first it was the right side now it seems to be both left and right, any idea why they might be getting hot and hanging up? I just changed the break pads about 3 months ago and they seem fine then
Old May 23, 2017 | 08:58 PM
dave944's Avatar
Sounds like one or more of the pads is binding and not releasing. I'd disassemble everything and check it out. Use brake grease on the ends of the pads where the metal backing plate fits into the caliper slide assembly and where ever the backing plate contacts the caliper. I also use brake grease on the back of the pad where it contacts the caliper piston.
Old May 23, 2017 | 11:21 PM
spikkeman's Avatar
I did that and the calipers and the pads are fine I checked the master cylinder and it had thick gel like fluid in it so I bled out all the break fluid and put new fluid in, now I'm having trouble getting break pressure built up when pumping the break peddle I bled all the calipers starting on the back right then back left ,right front and then left front 'it seems like the master cylinder is not pumping up correctly could the master cylinder gone bad from all the pumping and system bleeding
Old May 24, 2017 | 08:20 AM
dave944's Avatar
Ahh.. See me reply to the other thread.. It very well could be some crud in the master cylinder not allowing the system to depressurize fast enough after releasing the pedal. If it's been on there a while, it might not be a bad idea to go ahead and replace it while you're messing with it.
Bip
Jul 7, 2006 09:32 PM
Dstranks
May 15, 2006 02:55 AM
honaker
Feb 17, 2006 12:00 AM
Dudek12
Jun 1, 2005 11:11 PM
sailor1313
Nov 26, 2004 09:03 PM
