BROKEN OIL TEMP SENSOR
Old 02-13-2008, 10:42 PM
NewJ_A4's Avatar
Member
Default BROKEN OIL TEMP SENSOR
My oil temperature gauge doesnt budge. Do i have a bad gauge or do i have a bad sensor somewhere? PLEASE HELP
Old 02-13-2008, 10:44 PM
dankhound's Avatar
Default RE: BROKEN OIL TEMP SENSOR
Probably a bad sensor.
Old 02-13-2008, 11:47 PM
NewJ_A4's Avatar
Member
do you know if that is an easy DIY fix or is it something i should bring to the dealer
Old 02-14-2008, 02:40 AM
auditech79's Avatar
It depends, some engines have the oil level sensor and oil temp integrated into the same sensor. This would be easy to change because its bolted to the oil pan which is just a couple of bolts. Some sensors are mounted to the oil cooler ect which isn't easy to change. Check with the dealer parts dept. with your VIN number to see what you have.
Old 02-14-2008, 11:12 PM
KevinV10's Avatar
auditech79 that quote at the bottom of your posts.. did a mercedes owner really ask you that? thats hilarious. is there more to that story?
ultimate_audi_77
09-29-2012 08:11 PM
Scaryfatkid
11-12-2010 05:26 PM
toboater
10-26-2010 12:15 PM
Quick Reply: BROKEN OIL TEMP SENSOR
