CEL ON! HELP VAG_COM CODES Oxygen Sensors?
Old 06-30-2008, 10:16 PM
tj19855's Avatar
Default CEL ON! HELP VAG_COM CODES Oxygen Sensors?
Monday,30,June,2008,20:46:21:27272
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number:
Component and/or Version:
Software Coding:
Work Shop Code:
3 Faults Found:
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 008 - Implausible Signal - MIL ON
16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit
P0150 - 008 - Implausible Signal - MIL ON
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 002 - Lower Limit Exceeded - Intermittent
Old 07-01-2008, 10:22 AM
CRAZYHAWK's Avatar
Default RE: CEL ON! HELP VAG_COM CODES Oxygen Sensors?
Reset the codes and see if they return. I think the temperature sensor
is causing all the codes.
Old 07-01-2008, 01:06 PM
tj19855's Avatar
Already did many times, i just ordered a new temp sensor.
Old 07-01-2008, 01:40 PM
looking at the codes I would say that is a good choice
Old 07-01-2008, 06:33 PM
tj19855's Avatar
well hopefully is the temp sensor
ArcticZ
02-05-2010 02:21 AM
tj19855
07-02-2008 09:04 AM
brimhall99
06-22-2008 03:03 PM
cabrioman1995
06-04-2006 01:41 PM
gotaudi
05-16-2006 02:58 AM
Quick Reply: CEL ON! HELP VAG_COM CODES Oxygen Sensors?
