Check engine light on a 1996 audi a4 2.8l
Old Nov 27, 2007 | 09:42 AM
audi187's Avatar
Default Check engine light on a 1996 audi a4 2.8l
Found codes #16785,,egr valve getting vacuum, egr temp sensor changes when vacuum applied to egr valve, egr valve holds vacuum, idle changes when vacuum applied to egr valve” this is what my mechanic told me, he resets my ecu and the light goes back on every 600 miles and now it goes off for 4 days then back on every couple months!!! what should i do first replace the vacuum cylinoid then the egr valve or could it just be a o2 sensor
Old Nov 27, 2007 | 10:37 PM
KevinV10's Avatar
Default RE: Check engine light on a 1996 audi a4 2.8l
thats not a code... it would be a letter and then 4 numbers..
Old Nov 29, 2007 | 03:04 PM
audi187's Avatar
um no !! it even says it in my repair manual
Old Nov 29, 2007 | 03:18 PM
techbod's Avatar
16785 = EGR system insufficient flow detected, probable causes are hose leak/blockage, basic settings not carried out, EGR valve/solenoid ( im going for hose leak/blockage ) but also tempted to say clean the EGR valve out, as for the code its a 5 digit VAG
Old Nov 29, 2007 | 03:24 PM
audi187's Avatar
i payed 200 bux for the whole valve and port to be cleaned so im gonna prolly do the cylinoid first
audi187
Sep 25, 2007 09:47 PM
audi187
Aug 30, 2007 06:52 PM
pluto126
Aug 13, 2007 03:21 PM
rmazook
Oct 9, 2006 03:26 PM
rmazook
Oct 8, 2006 09:29 PM
