Check engine light - reprogram computer?
Old Oct 5, 2006 | 02:22 PM
svbing's Avatar
Default Check engine light - reprogram computer?
Check engine light came on - dealer says needs to update/reprogram computer - they had recently received tech serv bulletin......$400.....anyone run into this?
Old Oct 5, 2006 | 02:49 PM
CRAZYHAWK's Avatar
Default RE: Check engine light - reprogram computer?
You should state the year and model. Upgraging the ECU should be free.
If it's not free take it to AutoZone and have them read the codes.
Let us know what they are.
Old Oct 5, 2006 | 03:13 PM
A4H!PSI's Avatar
i have a 2000 a4 manual, with APR's stage3 turbo kit. i am getting P0422 code. bank1 maincatlyst below threshold. i am already running a custom testpipe file from APR to try and eliminate the code and it didn't work. plz help i have to pass emission in my state in 20 days or so and they fail for check engine lights in stl missouri
Old Oct 5, 2006 | 03:16 PM
CRAZYHAWK's Avatar
Work with APR to find a fix.
Old Oct 5, 2006 | 03:39 PM
Coop's Avatar
your gettin that code because you have no cat. you either need to get an O2 simulator or some custom ecu programming.
Old Oct 5, 2006 | 05:38 PM
A4H!PSI's Avatar
coop. i have heard of this o2 simulator once before. could u explain what i could see a picture of this, what it is, how it works.. or anything. i just need my car to pass and any enlightnment would help.
Old Oct 5, 2006 | 07:11 PM
techbod's Avatar
http://www.mkiv.com/techarticles/oxy...tor/index.html
[IMG]local://upfiles/12092/2F273E1C4A8B4E1F869E5E460AEC20D0.jpg[/IMG]
parlayin
Feb 10, 2010 12:33 PM
gldaudi
Oct 8, 2009 09:50 PM
svbing
Oct 14, 2006 01:15 PM
svbing
Oct 5, 2006 02:24 PM
