Cold air intake help
Old Jun 25, 2009 | 07:06 PM
jasonkp1978's Avatar
Default Cold air intake help
Hello I have a 2004 A6 3.0 Quattro and I was thinking of installing a cold air intake. First of all will this give me a def. boost in performance from the stock version? Also the intake im looking at has the adapter to put the MAF sensor on but what is that plastic long tube that come out of the stock air box and proceeds underneath? I didnt look very closely to see where it goes but If i put a cold air intake do I just detach this? Im just wondering if I should even mess with it in the first place.
Thanks
Jason
Old Jun 27, 2009 | 03:15 AM
csswitzer's Avatar
that long tube going underneath is probably the tube grabbing air for the sencondary air pump.
Old Jun 28, 2009 | 08:38 AM
So if I add a cold air intake what do I do with that tube?
Thanks
Old Jun 29, 2009 | 12:08 PM
csswitzer's Avatar
my air intake kit came with a small filter that went on the end of that hose. the secondary air pump put air into the exhaust for the first few minutes the car is running, and then it shuts off. i put the filter on the tube and then secured the hose. hope this helps.
Old Jun 30, 2009 | 08:23 AM
Default air intake
Hello, which model intake did you get? So your saing that small long tube is still hooked up to your car and the new intake system?
Old Jun 30, 2009 | 04:29 PM
ImTheDevil's Avatar
The SAP draws air from the airbox into it through that tube, and then pumps it out to the engine. You put a small breather filter on the tube (you can get them at AutoZone for less than $10) so that you don't suck up dust and dirt into the SAP.
You'll see very little, if any, gain from the intake. Even the turbo engines see very little gain - the OEM system is very efficient. You will, however, get a nice induction roar under throttle above 4000 RPM and you'll never buy another air filter, so there are defnite benefits to having one.
lukestaah
Jul 28, 2012 11:26 AM
libr8ed
Dec 20, 2011 07:50 AM
blackheart
Nov 13, 2006 04:46 AM
russianari
Mar 24, 2005 03:12 PM
