coolant question for 2001 a4 1.8t 5sp
Old Mar 11, 2008 | 10:41 AM
bvnguyen516's Avatar
Default coolant question for 2001 a4 1.8t 5sp
2001 a4 quattro 1.8t... is there a special type of coolant audis use or anything... my coolant sensor says im running az little low and i just bought the car... just trying to make sure i use the rigth stuff... im hearing about green coolant vs pink coolant.... and any brand recommendations?
Old Mar 11, 2008 | 03:20 PM
CRAZYHAWK's Avatar
Default RE: coolant question for 2001 a4 1.8t 5sp
G-12 comes with the car.
Old Mar 11, 2008 | 06:56 PM
less_of_me's Avatar
G-12 is correct- but be careful of toping off. If you have G-12 in your car right now, your coolant will be pink. If you have the green stuff in your car right now, don't put G-12 in unless you plan on flushing ALL the green stuff out first. Having a mixture of the two will cause major problems for you over time as it will coagulate (sp). Sounds like you need to top off a bit - go buy some distilled water from your grocery store. It should be < 1.00 for a gallon.
AudiDriver2006
Dec 26, 2013 01:38 PM
cobrad4
Jul 26, 2011 11:52 AM
midohioguy
Jun 5, 2009 11:24 AM
pologoped2
Feb 18, 2009 04:12 PM
lroz
Jul 6, 2008 03:20 PM
