dash and temp. control gauges go out when lights are turned on
Old Nov 22, 2006 | 05:21 AM
dmc28's Avatar
Default dash and temp. control gauges go out when lights are turned on
I have a 97 a6, when lights are turned off the temp control and odometer lights work but when I turn my lights on they shut off and none of the dashlights work either, any suggestions???
Old Nov 25, 2006 | 04:33 AM
brandono's Avatar
Default RE: dash and temp. control gauges go out when lights are turned on
Long story short... You can remove the entire instrument panel and replace the bulbs that light up your guages. These bulbs are not supposed to be replaceable... Audi wants you to have to buy some VERY expensive parts just to fix your problem, but it's not necessary if you have some patience and a few basic tools. You can actually get the replacement bulbs from radio shack. I will say this though... It is common knowledge among the audi mechanics that when you go into the panel to fix some of the bulbs, a lot of the time some of the bulbs that were working before will not work once you get everything back together again. I don't know why this happens, but it happend to me and I've heard it's common. Hope that helps.
o0hmikee
Oct 31, 2011 05:29 PM
xfiles
Jan 31, 2010 10:06 AM
4ringcircus
May 15, 2009 11:21 PM
danmcc86
Feb 12, 2009 11:49 PM
dlt21
Jun 17, 2006 10:13 PM
