Diagnosing a rear wheel-bearing issue
Old Apr 24, 2009 | 08:10 PM
Darkprodo's Avatar
Originally Posted by dlcain
I have a slightly different situation. when I turn hard left the noise stay's the same and doesn't get louder. when I turn hard right the noise completly goes away. Is this a wheel bearing issue? which side? also, I plan on doing most of the work myself with exception of getting the bearing pressed out & in. I read on another thread to leave the speed sensor connected and feed the wire down thru from under the passenger seat? Is there any other tid-bits of information I should know about while doing this? thanks !
its like a 4mm allen that holds the speed sensor in... thats all you have to do is remove it and let it hang
Old Apr 24, 2009 | 09:05 PM
ImTheDevil's Avatar
Two things about that - first, not all cars have bolt-in sensors. My 99 for example - it presses in. Second, the only reliable way I've found to get them out is once the hub is off, put the end of a socket extension on the face of the sensor closest to the bearing and gently tap it out. If your bearing is bad enough to hear, the heat in the hub has probably seized it. You'll probably destroy it trying to take it out. Given that and the fact that leaving it in the hub is fine while changing bearings (and unplugging the harness is easy), don't risk ruining it when it's unnecessary to do so.
Kyle_vdk
Jan 11, 2014 10:25 PM
ntriska
Nov 11, 2009 05:15 AM
spongebob
Jul 8, 2008 09:33 PM
palendromer
Jul 10, 2007 01:59 PM
azaouk
Jan 16, 2006 07:00 PM
