flasher/indicator problem
Old May 19, 2007 | 10:07 AM
mungot's Avatar
Default flasher/indicator problem
Hi.
I have an A6 Avant, 1.8T, year 2000 model
My indicators stopped working on both sides so, having searched online for the answer, the most likely culprit seemed to be the flasher module (incorporated behind the hazard warning switch) as the hazard lights still worked but indicators didn't. I changed it this morning for a new one from my Audi dealer.
Tip in passing: Those who also struggle to get the old module out, use a pair of pliers around the red hazard switch and yank hard!
Anyway, I installed the new module and the problem is still there. So what else could be wrong? Any advice would be gratefully received!
Bulbs are all OK
Fuses are OK
Thanks.
Old May 19, 2007 | 11:38 AM
GeilKyle2's Avatar
Default RE: flasher/indicator problem
the switch itself could have failed
Old May 19, 2007 | 11:39 AM
GeilKyle2's Avatar
or a wiring issue
Old May 26, 2007 | 05:29 AM
mungot's Avatar
it was the switch inside the steering column in the end - had to get the dealer to do unfortuntely[:@]
andyklark4118
Jun 20, 2015 06:02 PM
youngjerryg
Apr 12, 2009 10:52 PM
rob 1234
May 13, 2008 10:22 AM
