Indicator flasher unit
Old Apr 11, 2009 | 04:53 AM
youngjerryg's Avatar
Default Indicator flasher unit
Indicators on my 2001 A6 avant wont work. The hazord lights are still working fine so there are no bulbs out. how do i find the flasher unit and replace it?
Old Apr 12, 2009 | 10:52 PM
ImTheDevil's Avatar
The flasher relay is built into the hazard switch. If it's the relay going bad, chances are your hazards will stop working shortly. If not, it's either a blown fuse or a faulty turn signal switch. That assembly is built into the switchbox at the base of the stalk, inside the column. You'll have to pull the airbag and steering wheel to access it.
Nigel
Sep 13, 2014 06:10 PM
malubeast21
Sep 28, 2008 11:19 PM
malubeast21
Sep 23, 2008 11:33 PM
rob 1234
May 13, 2008 10:22 AM
mungot
May 26, 2007 05:29 AM
