grinding noise on first gear only HELP!!!
Old Dec 13, 2005 | 10:30 PM
crega001's Avatar
Default grinding noise on first gear only HELP!!!
if anyone could help me out.. here's the problem: i have a 98 A4 1.8T manual tranny. when i put it in first gear and accelerate, it makes this grinding noise. i don't know where it's coming from but it only happens on first gear. does any one know what it could be???
Old Dec 14, 2005 | 12:12 AM
2000Sforce.dtwaudi's Avatar
Default RE: grinding noise on first gear only HELP!!!
how many miles? Is it a grinding or more sounds like a diesel car. Im guessing you are missing teeth off the gear. Happened to a friend of mine.
Old Dec 14, 2005 | 03:37 PM
crega001's Avatar
car has about 122, 000 miles. it's more of a grinding noise, but only happens when i put it in first and accelerate. how can i fix this problem?
Old Dec 18, 2005 | 02:59 AM
Dj Spiel's Avatar
I have same problem, but only when I accelerate fast! If I take my car from 1000RPM to 7000RPM slowly its fine.However if I try to gas it vert fast it grinds. (and only in first)
Problems Below.
1st--------Bad Syncro -->Synchro is cheap. However labor will cost liek 1000 to 1500
2nd------- I read that it could be clutch also like not installed properly. DId you recently get your clutch replaced?
ORIGINAL: crega001
Old Dec 18, 2005 | 04:10 AM
crega001's Avatar
when i bought the car it grinded, but the thing is the grinding noise became more and more noticeable. at first it was quiet then gradually got louder and louder. the clutch i think is rather new, but i don't know. i guess i would have to check with the previous owner. the only thing i hate about audi is that mechanics think they can charge you an arm and a leg because it's an "audi".
zachaTTack
Jul 26, 2007 06:50 PM
L.E.O.
Mar 25, 2007 09:35 PM
gregp1962
Mar 12, 2007 06:34 PM
aj
Nov 22, 2006 01:34 PM
cukilo
Feb 16, 2005 12:29 PM
