groaning noise
Old Apr 23, 2007 | 03:45 PM
johnnyboy101's Avatar
Default groaning noise
So, lately, I've noticed a groaning noise when i drive at low revs and turn (usually when I am parking and pulling out) I have a 1998 audi quattro a4. Once I speed up, the noise disappears. The steering is also a bit stiff as well while this groaning happens. Any ideas? I appreciate the help!
Old Apr 23, 2007 | 04:47 PM
LampyB's Avatar
Default RE: groaning noise
if the groaning occurs when you turn the wheel to one side, but then goes away when the wheel is turned to the other side it is probably a bad wheel bearing...something you prob. can't change yourself.
if the sound comes on with the wheel turned to the left, its a bad bearing on the right side of the car. if you turn right and it groans, it's a bad bearing on the left side. not a big deal, but don't drive on it for too long or the wheel could sieze up and then your in serious trouble (and its extremely dangerous if this happens on the highway at like 80mph!). should cost anywhere from $150 to $300 for the bearing replacement...i'd advise not going to a dealer because any mechanic with a press can do the work much cheaper.
LampyB.
Old Apr 23, 2007 | 05:00 PM
myaudi98's Avatar
Could be two people having relations in your car? lol jk
I say just go have checked out at a stealership.
Old Apr 23, 2007 | 10:41 PM
GeilKyle2's Avatar
check your power steering fluid, probably low, or your pump is getting tired
Old Apr 24, 2007 | 03:04 AM
Flip's Avatar
Power steering system is the most likely cause.
pcelias
May 2, 2013 10:41 PM
galat216
Mar 14, 2008 09:19 PM
me.hansen
Dec 11, 2007 11:15 PM
bookem1964
Aug 23, 2007 09:42 PM
audiboy12
Dec 11, 2006 03:39 PM
