The heater noise
Old Nov 29, 2006 | 04:59 AM
kriptonik's Avatar
Default The heater noise
Hey guys,
Since it's getting pretty cold in Southern California, I recently need to use the heater in my A4.
One thing I found that annoyed the heck out of me is the noise the heater makes everytime it's turned on.
The noise is coming from the right side of the dashboard (It's a screeking noise that sounds like a bird/cricket).
I searched the forum but could not find the way to fix it.
Has anyone here able to fix this problem on their own or do I need to take it to the dealer?
Thank you in advance.
Old Nov 29, 2006 | 04:28 PM
puremskirby's Avatar
Default RE: The heater noise
When was the last time you used the fan (AC or just the Fan)? If it has been a while you may want to gain access to the fan and lube the bearings or check and see if something got into the fan whether it was alive when it did or maybe a leaf fell in.
Old Nov 29, 2006 | 05:18 PM
techbod's Avatar
to get to the blower motor you have to remove the glove box to gain access, you can only gain access to the fan blades through the plastic cover where the pollen filter is ( below the windshield wipers ) you will probably find a lot of leaves in there
Old Nov 29, 2006 | 10:00 PM
kriptonik's Avatar
I got the car about couple of months ago.
I use the AC every single day so the sound goes off only when the heater is on.
Avant, I got a little confussed from your instructions. Are you saying I should clean/lube the part from inside the glove box or the part inside the pollen filter.
Also thanks for the quick responses.
Old Nov 29, 2006 | 10:53 PM
He is saying that if there are leaves you can clean them out from accessing them through the pollen filter from under the windshield wipers. to get to the blower motor you have to remove the glove box.
the thing is that you use the fan all the time so it is probably leaves in the fan blades.
Old Dec 1, 2006 | 03:55 AM
kriptonik's Avatar
Thank you for clearing that puremskirby.
I will start working on it soon as I find the time.
Old Dec 19, 2006 | 12:46 AM
mwent's Avatar
You should read this. It is a great write up on the blower behind the glove box. http://www.audiworld.com/tech/elec132.shtml
kozhouse
Feb 21, 2014 03:02 PM
little_town_audi_owner
Jun 27, 2013 10:37 AM
Jackmup
Dec 24, 2012 09:30 AM
Mashina
Mar 10, 2008 09:08 PM
sollyd25
Jan 17, 2008 10:31 AM
