Help with 99 A4 2.8 Quattro not starting
my 99.5 Audi A4 Quattro cranks but doesnt start first i thought it was the fuel pump but the fuel pump is good cuz the lines have fuel pressure, im not getting a spark from the spark plus wires. unless im not checking it properly and my crankshaft sensor has a resistance of less than 1000. How should i check i if my coil packs are good and is my crank shaft sensor gone if it is gone would it do this? thanks is advance
Edit/Delete Message
Edit/Delete Message
