help... My audi is stalling and shaking violently
Old Dec 25, 2005 | 04:02 AM
Scot's Avatar
Default help... My audi is stalling and shaking violently
about 2-3 weeks ago I got a 93' Audi s4 Quattro Turbo 5 speed manual. In the mornings when I start it in order to warm it up, it sometimes stalls minutes later. It dosn't seem to stall once I drive it around a little bit though. I figure this problem is just from the car being old.
The biggest problem I'm having is this violent shaking. Sometimes when I accelerate quickly or travel at high speeds. This dosn't happen to often, just every once in a while. I could be driving down the street picking up speed while sustaing a perfectly smooth ride, and within a second or so my car rapidly starts shaking side to side it feels like. When this happens I let off the gas and lightly brake and usually it goes away in a few seconds, but while it's going on it feels like I could get into a car accident it's so bad.
I'm not too sure if the stalling and the shaking are connected it some way. I don't know much about cars, but my only guess is that the violent shaking is cause by my engine not getting fuel fast enough or efficiently enough. The stalling might also be from not getting fuel efficiently. My guess is the fuel system, but that's just a random guess. I'd really appreciate any input because I'd like to get to the bottom of this incase it's sometime serious.
Old Dec 31, 2005 | 05:01 AM
dankhound's Avatar
Default RE: help... My audi is stalling and shaking violently
Your car may just be in need of a tuneup. Whens the last time the plugs and wires were replaced?
Old Jan 5, 2006 | 05:04 PM
Ultra sport's Avatar
Is the motor only or the whole car shaking? If it is the whole car I would check your wheels to make sure the lug nuts are tight. I had this happen and the car would start shaking only at highway speeds and would settle back in if I slowed a bit. The stalling my be a seperate issue that a tune up could help it could be a sticking choke or an idle adjustment issue. I'm not a mechanic so I'm not sure how much on a 93 was computer controlled and how much is manual.
Old Jun 21, 2006 | 07:02 PM
crashnburn's Avatar
Check main hose under air breather going to the throttle body...they usually get oil soaked and rot, fall apart and tear from the stress from stop and go, one day BANG one great big vacuum leak !
Check there first.
Crashnburn
Old Jun 21, 2006 | 07:04 PM
techbod's Avatar
yep ^^^^^
Reptarr
Nov 24, 2013 08:10 PM
Vabbe sci CIAO!
Jan 26, 2011 12:44 PM
Bip
Sep 13, 2010 05:50 PM
andyblake
Aug 9, 2010 07:57 PM
cdb555
Oct 14, 2006 12:54 AM
