Audi A4 '97 1.8 Keeps stalling - help please!
Old Oct 10, 2006 | 07:28 AM
cdb555's Avatar
Default Audi A4 '97 1.8 Keeps stalling - help please!
Hi there, i have an Audi A4 1.8 5v which has always been ultra reliable until today - it starts, but will not hold its idle - as soon as i let it go below 1000rpm it dies straight away - i can only keep the engine running by keeping my foot on the accelerator - does anybody have any suggestions what may be causing this to happen? Your help is really appreciated
Old Oct 10, 2006 | 08:34 AM
techbod's Avatar
Default RE: Audi A4 '97 1.8 Keeps stalling - help please!
idle control valve if the CEL is on if not a vacuum pipe has came off which is more than likely
Old Oct 10, 2006 | 08:22 PM
luvin_the_rings's Avatar
yea, either the valve or no vacume
Old Oct 11, 2006 | 07:10 AM
cdb555's Avatar
Thanks guys for the replies - do you know if there is a way of me checking the vacuum - or if there are any visable signs?
Old Oct 11, 2006 | 07:38 AM
techbod's Avatar
just look for pipes off or split, tighten all hose clips
Old Oct 11, 2006 | 09:41 AM
cdb555's Avatar
Cheers Dave - I know this will sound stupid but are most of the pipes around the top of the engine or would there maybe be some around the bottom?
Cheers
Chris
Old Oct 14, 2006 | 12:54 AM
dankhound's Avatar
All over the place. You have some really big hoses that go from the turbo on the left side of the engine to the intercooler on the right front. Then to the throttle body. There are quite a few vacuum hoses that are behind and under the intake manifold. And a bunch more near the turbo. From the sounds of it you have a really big vacuum leak. You should hear a sucking type sound as the engine dies. Find the sucking sound and you have your leak. Also try unplugging the maf snesor. If it runs better you probably have a bad maf. You may also want to try cleaning your throttle body.
cannibus-tokus
Feb 23, 2013 07:00 PM
pcurtice
Sep 29, 2011 11:36 AM
syndrome69
Nov 12, 2006 11:18 PM
dons_one
Sep 12, 2005 09:24 PM
K69camaroz28@aol.com
Feb 4, 2005 02:11 PM
