Help! My car stopped running!
Old Sep 21, 2009 | 04:50 PM
Prizmatik's Avatar
Question Help! My car stopped running!
I recently purchased a 1997 Audi 1.8T for $800 because it was running poorly with smoke coming out the exhaust. I determined the turbo was bad and purchased a used turbo. I installed the turbo and the car started right up and seemed to run well, with smoke coming out the exhaust, but I was hoping the remaining amount of oil would be burnt off. I ran the car for about 5 minutes then turned it off to check a trouble code. The code was for a bad coolant temperature sensor which was previously there. Then I try to start the car up, and it just wont start. It cranks just fine, its getting fuel and spark, the timing is good, the compression is between 118-128 for all four cylinders. I cant figure out what is wrong, Please Help. Thank you.
Old Sep 22, 2009 | 03:45 PM
Prizmatik's Avatar
UPDATE:
So I left the car alone for the rest of the day and the next morning I attempted to start the car and it struggled a little bit, but started up. I turned it off after 45 seconds or so. Then I tried to start it again and it started right up, and I took it for a test drive and it is running good. Since then its starting fine.
I dont know what the problem was, but maybe putting a different turbo on threw the computer off and it had to adjust??? Who knows, but at least it started up!!
Old Sep 22, 2009 | 07:57 PM
Midniteoyl's Avatar
Its the temp sensor...
Old Sep 23, 2009 | 11:23 AM
Prizmatik's Avatar
The temperature sensor is what was causing it not to start? Thats wierd.
Old Sep 23, 2009 | 12:53 PM
Midniteoyl's Avatar
Seems so, but I had the same prob on a Ford.. it would start and run after sitting for 2 hours, but not while warm. Eventually it would just die after about 10 mins of running. Everyone said it was the MAF, dealer included. I swapped them and didnt change anything. Eventually I found there were two temp sensors; one single wire for the gauge, and one dual wire for the ECU. I swapped the dual wire one out and it started working perfectly. It seems that when these fail, they fail Low or High. If Low, the ECU thinks its -40F all the time which will allow the car to start cold but not run when it warms up. If High, its the other way around - the car is hard starting, but runs good warm.
Not saying that this is the prob for sure, but since you already have a code for it...?
Old Sep 23, 2009 | 04:12 PM
Prizmatik's Avatar
Cool, I love to hear new information from other peoples experiences. Diagnosing is the hardest part in automotive repair.
I purchased a new temperature sensor for the car, but I cant find where it goes. I have found a four wire fan switch sensor that is in the rear of the engine, this coolant temp sensor is a two wire, but cant find where this darn coolant temperature sensor. Thanks for the input.
Old Sep 24, 2009 | 03:11 AM
lenchnikin's Avatar
Default Help My car stopped running
Hi, Im trying to login on a shard running POL096
with their client and since there was no "signature" i ran ilPatcher for it to build.
It did but doesnt find Decrypt 1 key, and login fails - stalls at verifying.
Also using option: same as client . doesnt work but the client alone logins.
it returns:
Code:
PNGento2
Feb 5, 2014 10:17 AM
Truthalive7
Oct 9, 2011 11:28 PM
Truthalive7
Sep 22, 2011 10:57 PM
caffel
Dec 24, 2010 10:45 PM
JIMS6
Jan 24, 2008 10:34 PM
