How to clear codes?
Old Apr 29, 2011 | 11:05 PM
bkosonen's Avatar
Default How to clear codes?
So I ordered up the OBD interface from eBay and downloaded the light vag-com but still can't read or clear codes. Any one can help ?
Old Apr 30, 2011 | 05:44 PM
02A6Beau's Avatar
are you getting errors when you try to connect?
I'm guessing you got the usb interface? Have you made sure that VCDS (the software) is configured for usb? You need a usb driver, and you need to set up the software for usb in options.
Old May 1, 2011 | 03:13 AM
bkosonen's Avatar
Yeah I have the Ebay cable. I set up so it reads the right COM port, When I test it in VAG-COM it says OK and everything, just when I click on Engine under modual it says unable to connect.
Old May 1, 2011 | 06:21 AM
02A6Beau's Avatar
Try checking the Ross-Tech FAQ HERE
unfortunately sometimes the ebay cables never end up working properly
good luck
Old May 1, 2011 | 11:51 AM
bkosonen's Avatar
Yeah. I might just get a reg. OBD2 scanner. This VAG-COM is a Pain in the *** lol.
Old Jun 3, 2011 | 08:03 AM
ImTheDevil's Avatar
No, if anything get a better cable. For Audi, Vagcom is FAR superior to a scantool. I had the shareware version and that was good. Now I have the unlocked version and it's unbelievable how much you can do with it.
Old Jun 17, 2011 | 02:21 PM
Jeff M's Avatar
Where is the best place to get the unlocked version? Also, can it program new keys? I thought I read somewhere that Vagcom is used to program keys, but I can't find where I read that. I only have one key and need a few more, but the nearest place that will do the programming is 2 hours away.
kchao2000
Oct 20, 2011 09:15 AM
joenelson7687
Aug 25, 2010 04:10 AM
a88fl1
Jun 28, 2007 04:50 PM
