I need help with VAG codes
Old May 11, 2007 | 03:59 PM
Mac_17's Avatar
Default I need help with VAG codes
I pulled the codes when the cel came up. I have to smog my car soon so is this going to trip up a smog test.
17539 p1131 035
Bank2-Sensor1
resistant too high
sporadic DTC
Let me know what his code is refering to and what I can do to fix it.
I have a 2000 2.7t, with apr chip, bipipe and dv's.
Old May 11, 2007 | 04:05 PM
techbod's Avatar
Default RE: I need help with VAG codes
[IMG]local://upfiles/12092/C7E628BC9CFB41948CF5C4340DB6A4E8.jpg[/IMG]
[IMG]local://upfiles/12092/0D83A574DAEF43168C362BDC04669E60.jpg[/IMG]
Old May 11, 2007 | 05:58 PM
CRAZYHAWK's Avatar
O2 sensor.
Dave, I can't read your scans.
Old May 11, 2007 | 06:09 PM
Mac_17's Avatar
Guys thanks for the help. Anychance you guys know the part number for that 02 sensor and where it is located. Is it the o2 next to the cat.
Old May 12, 2007 | 11:28 AM
CRAZYHAWK's Avatar
Sensor 1 should be pre-CAT.
Old May 12, 2007 | 01:32 PM
2k S4's Avatar
Passenger side, pre cat. Replace it with a new one, chances are the drivers side is on it's way out, so might as well do both.
Old May 12, 2007 | 03:34 PM
techbod's Avatar
ORIGINAL: CRAZYHAWK
O2 sensor.
when you click on the picture and it opens you have to move the mouse pointer out of the picture then back in and you will see the enlarge button on the lower left of the picture, it only stays there for a few seconds so if you miss it just move the pointer outside again then back in to make it come back
Old May 12, 2007 | 06:20 PM
CRAZYHAWK's Avatar
Thank you, David.
Old May 13, 2007 | 12:04 AM
S4LIFE's Avatar
i had the exact same code and got it fixed about a week ago. the egt sensor cost me 315 dollars its called lambda probe
markymarc
Sep 8, 2010 01:59 AM
joenelson7687
Aug 25, 2010 04:10 AM
Ruggedboy
Jul 20, 2007 11:30 PM
supercoupe91
Jul 13, 2007 06:20 PM
rafa_207
Jun 27, 2007 01:31 PM
