Instruments + Information Radio
Old Oct 26, 2007 | 09:08 PM
LEANDRO's Avatar
Default Instruments + Information Radio
Hello... I changed my instrumets painel every is works good, but the information about Radio. (FM/AM) can not displayed in the instruments painel.
Someone knows how canI solve this ??? Is there step by step that I need to do in VAG to solve this.
regards
Leandro
Old Oct 28, 2007 | 12:22 PM
dankhound's Avatar
Default RE: Instruments + Information Radio
Check your coding to make sure it is correct. I do believe there is an adaptation that needs to be performed for this to work. Unfortuanatly id dont recall which one needs to be changed to what.
Old Oct 28, 2007 | 12:56 PM
LEANDRO's Avatar
ok.. tks.. but what coding did you mean ???? 8L920930M (Instruments) or coding to put in VAG software ??? where can I find this code ???
regards
Leandro
Old Oct 28, 2007 | 01:00 PM
techbod's Avatar
a little information on what car/engine/age could help
Old Nov 1, 2007 | 07:41 PM
tHe kNiGHt FaLL's Avatar
i'm confused...
are you guys audi techs... or just know alot about service...?
first off.... what VAG are youpossibly going to use...?
the procedure for replacing a cluster... is using a VAS 5051/52 you need to store all adaptation channels in the scan tool, install new cluster and burn the data into the new cluster.
now you said everything works so somehow you accomplished this.
your instrument cluster needs to be coded to the radio... which should have been done when you replaced it.
if it didn't.... using a VAS 5051/52 coding and or adaptations need to be checked. for both the radio and the cluster.
and coding is not software version... coding is where you tell the instrument cluster control module J285 wha size gas tank, trans type, vehicle location... blah blah blah. and it comes up w/ a code and is store in the module.
Old Nov 1, 2007 | 07:46 PM
ORIGINAL: techbod
[sm=pcwhack.gif]
my thoughts always
Old Nov 3, 2007 | 11:43 AM
dankhound's Avatar
Sometimes the 5051 transfers everything over properly. Sometimes it doesnt. The adaptation is different than the coding. I dont have a vagcom so i dont know if it is possible to change the adaptation, but i think it would be possible.
Old Nov 4, 2007 | 08:52 PM
ORIGINAL: dankhound
very true... but it will tell you how many channels were... and which weren't.
in function description.
it is possible to change. you just need to kno the channel number and whats being adapted
jabbawoki
Sep 9, 2008 03:16 PM
LEANDRO
Oct 28, 2007 08:25 AM
kstrike155
Oct 14, 2006 03:10 AM
GOGIRL
Nov 23, 2004 06:39 PM
