Intake Manifold Help
Old Apr 12, 2008 | 05:31 PM
amiller86's Avatar
Default Intake Manifold Help
Ok, so I was installing a boost gauge and running the hose from the gauge to the barb on the front of the intake manifold. It had a hose which runs down to a black box shaped thing under the manifold. (maybe something for fuel pressure???) Anyway I was taking the one time use clamp off (and all I could remeber washow much of a PITA they werewhen I had to install my dv), so I put some serious torque on the clamp....ending with the brass barb shearing off the manifold. The dealership says they are pressed in at the factory in Germany, so I ordered a new one. Is there anyway I can rig my car so it runs? Right now they are sayig atleast a month before the part come from Germany!!! I need my car... any help would be great..including anyone who wantsto sell a 2005 1.8t intak manifold.
Thanks
Old Apr 12, 2008 | 07:31 PM
tHe kNiGHt FaLL's Avatar
Default RE: Intake Manifold Help
could you supply a picture of the pieces broken...?
Old Apr 13, 2008 | 11:47 AM
amiller86's Avatar
yeah, sorry I didn't think to take pictures right after it happened. So you'll see epoxy holding it in place.. I thought I'd try that before I took the think off the engine and to a machine shop. Anyway it's the brass barb in the pictures (follow the link.)
http://www.uvm.edu/~amiller3/Audi/
Thanks
Old Apr 13, 2008 | 05:56 PM
KevinV10's Avatar
nice repair job.. that didnt work? haha, no just joking. looks like its just a vacuum hook up. you could plug the hole, and use some other plastic tee's to share another vacuum source. just be sure its coming from the same section of the manifold. differnt sections will have differnt vacuum. if you plan on making the repair properly when that peice comes in. be sure not to plug off the hole permenantly.
Old Apr 13, 2008 | 08:43 PM
amiller86's Avatar
ORIGINAL: KevinV10
yeah thats what I waswondering about.. There is nothing else around the front fo the manifold. I didn't want to toff something that would end up causing more problems. I talked to some mechanics and they said it was for the fuel pressure, so f***ing with that seems like ti could be sketchy.. Do you know which line would be acceptable to tap into?
Oh and I realize how bootleg it was to try and epoxy it back on, but I thought I'd atleast try it.
Old Apr 14, 2008 | 02:27 AM
milehighpilot's Avatar
they do sell nipples with threading on them, so you could drill out the old piece, then tap it and install the new nipple. but im not sure where you can get the part, i know a local auto shop like Murry's can order them. and dont forget to take the intake mani off cause of the netal shards that will fall inside.
Old Apr 14, 2008 | 09:37 AM
zippy_gg's Avatar
ORIGINAL: milehighpilot
+1. I would take the thing apart and to a machine shop if you don't have the tools to thread a new part in. A good machine shop might even find the right part for you, or at least point you in the right direction.
Old Apr 14, 2008 | 03:25 PM
amiller86's Avatar
Yeah, I will look into that... wanted to avoid taking the manifold off, but looks like I gotta. Thanks to everyone who has povided suggestions
RaivisGertners
Nov 11, 2018 11:15 AM
David Narez
Jun 26, 2013 09:20 AM
ryanjayblair
B7 Models
May 28, 2009 05:13 PM
True_Pinoy
May 5, 2006 06:54 AM
K69camaroz28@aol.com
Mar 1, 2005 07:57 PM
