Intake Manifold Help
Ok, so I was installing a boost gauge and running the hose from the gauge to the barb on the front of the intake manifold. It had a hose which runs down to a black box shaped thing under the manifold. (maybe something for fuel pressure???) Anyway I was taking the one time use clamp off (and all I could remeber washow much of a PITA they werewhen I had to install my dv), so I put some serious torque on the clamp....ending with the brass barb shearing off the manifold. The dealership says they are pressed in at the factory in Germany, so I ordered a new one. Is there anyway I can rig my car so it runs? Right now they are sayig atleast a month before the part come from Germany!!! I need my car... any help would be great..including anyone who wantsto sell a 2005 1.8t intak manifold.
Thanks
Thanks
yeah, sorry I didn't think to take pictures right after it happened. So you'll see epoxy holding it in place.. I thought I'd try that before I took the think off the engine and to a machine shop. Anyway it's the brass barb in the pictures (follow the link.)
http://www.uvm.edu/~amiller3/Audi/
Thanks
Thanks
nice repair job.. that didnt work? haha, no just joking. looks like its just a vacuum hook up. you could plug the hole, and use some other plastic tee's to share another vacuum source. just be sure its coming from the same section of the manifold. differnt sections will have differnt vacuum. if you plan on making the repair properly when that peice comes in. be sure not to plug off the hole permenantly.
ORIGINAL: KevinV10
Oh and I realize how bootleg it was to try and epoxy it back on, but I thought I'd atleast try it.
they do sell nipples with threading on them, so you could drill out the old piece, then tap it and install the new nipple. but im not sure where you can get the part, i know a local auto shop like Murry's can order them. and dont forget to take the intake mani off cause of the netal shards that will fall inside.
ORIGINAL: milehighpilot
RaivisGertners
Nov 11, 2018 11:15 AM
