Key Just Kept Turning in Ignition Without Starting the Car
Old Apr 16, 2012 | 09:43 AM
talontsi01's Avatar
Default Key Just Kept Turning in Ignition Without Starting the Car
Good Morning All:
Yesterday upon leaving the gas station, I put the key in the ignition, went to turn it and instead of "catching on anything to engage first the electronics, then to start the car, nothing happened. I could turn the key around 360 degrees again and again with very little resistance. And nothing worked either (electronics or starting of the car).
I had called for someone to come and get me and was about to push my car over into a vacant parking spot when I decided to try starting it again...and voila, it started. This happened last night. So, I drove it again this morning just fine.
Was it something I did last night that could've done something? Or is this an early warning sign that something is broken and if I keep driving it, I'll find myself stranded somewhere?
Thanks everyone.
Old Apr 18, 2012 | 03:44 PM
talontsi01's Avatar
Is it possible I broke something in the ignition? If I did, it hasn't malfunctioned again after probably 20 start-ups. Very odd situation...
Old Apr 20, 2012 | 10:57 PM
SUPERMARIO680's Avatar
My old BMW did the same thing once in a while, I jut had to push it in a bit further in. On the BMW people just put a set screw in to hold it from spinning.
Old Apr 22, 2012 | 11:18 PM
talontsi01's Avatar
Interesting...
I just don't want to get stranded somewhere at some point where it won't start at all. I really was very close to calling it quits in terms of trying to get it to start the night it happened.
I called a couple dealerships on a quote and it would be a minimum of about $450 to have fixed. For now I guess, it's not getting fixed as it actually only happened the one time and hasn't happened since.
Old Apr 23, 2012 | 05:25 AM
light8008's Avatar
Banned
Check all wire connections a coil and solenoid.
mariano_md
Jan 16, 2014 01:41 PM
MiniSpdRcr
Jul 19, 2012 06:42 PM
Boston - Audi96Q
Sep 17, 2011 10:26 PM
paul3141
Jun 26, 2010 03:39 AM
mbertoli
Nov 23, 2008 02:09 PM
