Key Programing..
Old Nov 27, 2007 | 03:41 AM
tse07's Avatar
Default Key Programing..
Anyone know how to program my car's key to my car? Switchblade key.
I have a 2003 a4 and im not sure if the key is dead, or if its just not programed. If anyone could help me out, it would be much appreciated...
Old Nov 27, 2007 | 11:12 AM
nemohm's Avatar
Default RE: Key Programing..
The Owners manual has the procedure for remote control reprogramming.
If the remote was working before, I'd start with battery replacement.
Old Nov 27, 2007 | 06:12 PM
CRAZYHAWK's Avatar
This works on A4s.
The following instructions are to reprogram your switchblade key fob.
1. Take a spare key and insert it into the ignition. Turn it one click forward.
2. Roll down your window just in case. Step outside the car, and lock the car with a second key.
3. With your second key fob press the unlock button. The lights should flash.
4. Now lock the car with the key fob, and then unlock it.
5. Remove the key from the lock and the key from the ignition, and try it's function
Old Feb 25, 2008 | 04:35 PM
Bjayfry's Avatar
Per the owner's manual on 2003 A4's you're supposed to do the following:
1. Press the unlock button on the remote control
2. Insert the ket into the ignition and turn it to the on position
3. Turn the key back to off
4. Pull the key out
5. Press either lock or unlock to complete the procedure
This worked on mine after I replaced the battery today.
hkrk2005
Jun 23, 2014 11:13 PM
vjmaudi
Mar 6, 2014 11:03 AM
luis_laet
Jan 31, 2009 04:29 PM
Soley4pres
Apr 24, 2007 09:46 PM
mjvss21
Jan 1, 2006 10:42 PM
