Lean
Old Oct 22, 2004 | 08:36 PM
Vader's Avatar
Default Lean
2000 S4 tip with APR 93 program
Recently my CEL came on. Codes were 1128 1130. Lean fuel on right and left bank. I thought it was due to 92 octane accidently put in. Code cleared and light came back on.
I am wondering if I have a vacuum leak after I installed my boost gauge.
Any other suggestions ?
Old Oct 22, 2004 | 11:04 PM
Jestnomen's Avatar
6th Gear
Default RE: Lean
Could be your MAF, BPV or vacuum.
Old Oct 23, 2004 | 01:50 AM
Vader's Avatar
Default RE: Lean
BPV are new.
How can I test vacuum or MAF ??
Thanks
Old Oct 23, 2004 | 02:50 AM
Jestnomen's Avatar
6th Gear
Default RE: Lean
I'd start by picking up a couple feet of vacuum line and replacing all that you can. The factory stuff gets brittle and cracks very easily. How much boost does your gauge say you are getting?
Here's an article to read.
Old Oct 23, 2004 | 12:52 PM
Vader's Avatar
Default RE: Lean
Thanks for the info. Boost is between 15-17 psi, vacuum is 20.
I believe it is the MAF, beside the Stealership, where is a place I can buy this. None of the local shops can get it
Old Oct 25, 2004 | 10:14 PM
Jestnomen's Avatar
6th Gear
Default RE: Lean
I just bought a used one from an auto dismantler. I found them on www.car-parts.com. Think I paid 40 bucks for the maf. The dealer also sells a remanufactured MAF for like 80 bucks I believe.
Old Oct 26, 2004 | 12:32 AM
Vader's Avatar
Default RE: Lean
Thanks, I went over to AudiWorld and looked up the procedure on how to clean the MAF. So far the CEL has stayed off.
MAT123
Nov 2, 2010 10:31 PM
skibum0019
Feb 10, 2008 08:06 PM
auditt225
Jul 29, 2007 05:21 PM
spam7788
May 23, 2006 08:53 PM
True_Pinoy
Jan 10, 2006 06:41 PM
