low brake pad warning indicator light
Old May 7, 2008 | 12:46 PM
koop's Avatar
Default low brake pad warning indicator light
I recently replaced the pades and rotors on my 97 A8 (4.2 quattro) with EBC redstuff pads and some performance rotors. The pads have the sensor on them and it is plugged in properly. I cleaned everything very well and doubble checked my connections. Yet the pad light is still on. Any ideas for getting the light out? Thanks for any help.
Jesse
Old May 7, 2008 | 08:10 PM
tHe kNiGHt FaLL's Avatar
Default RE: low brake pad warning indicator light
alot of aftermarket pads don't work correctly...
you'd have to disconnect the sensors and loop them w/ a paperclip. the sensors won't work but the light will go off
Old May 7, 2008 | 10:58 PM
koop's Avatar
Thanks a lot. I figured that might end up being the case. Anybody know which pins to jump? There are three.
Old May 8, 2008 | 10:40 AM
CRAZYHAWK's Avatar
Make sure the brake fluid is filled up. On some
Audis the same indicator is shared with warn
pads.
Old May 8, 2008 | 08:42 PM
audikidjr's Avatar
Not the same light at the low brake fluid.low fluid light is red.low front pad light is yellow and in center of cluster.i would try to jump at the connectors if light does not go out abs line is the cause.very common on A8.and if you saved your old pads cut the wires from them to make the jumpers.
Old May 13, 2008 | 10:36 AM
koop's Avatar
so I jumped the pins. The light is still on. Where is this abs line? And how do I know which line to replace?
A6owner2008
Oct 28, 2011 01:50 PM
yenkonova
Mar 21, 2009 02:50 PM
CRAZYHAWK
Nov 25, 2004 12:48 PM
tp
Aug 18, 2004 11:37 PM
