MIL Malfunction Indicator Light Autozone Codes?
I just bought an 1999 A4 1.8T a little over a month ago. I burned the fuel gage down to EMPTY. It is my guess that I was getting ready to run out of gas, (I was seeing what mileage you can get out of a tank...[;-)
Anyway, the MIL light came on not too long after. I took it to Autozone and got following codes.
P1250-Fuel Air Metering
PO116-
Engine Coolant Temp Range Perf
P1136-
Fuel Air Metering Code
When I first got the car, the coolant sensor light came on. I took it to the dealer, they reset it and said nothing was wrong. Now I am wondering why the coolant temp range perf code popped up and if this is just a conciedence, since the engine was probably running hot due to the fuel pump working over time, the pressure being off, causing the catylitic converter to get hot, causing the emmissions/mil to come on since the fuel mixture was also off.
The car seems to run great. The light is still on and it does not blink.
