Modified Airbox
This should be pretty self-explanitory. you want to remove the divider in the air box and the inital ram air scoop. I dont have anypictures because this was done so long ago.
1. Unplug all the sensors on top of the air box.
2. Remove theupper and lower sections of the airbox.
3. Find the intake on the bottom part of the box. (It should be an retangular shape and have a divider in it.)
4. Use a razor blade or someother cutting device and start to cut along the sides of the divider. once you get as far as the blade takes you break the divider off with you fingers.
5. Repeat untill divider is gone.
