My buddy's golf- died on him
Old Feb 28, 2007 | 04:26 AM
wood_e's Avatar
Default My buddy's golf- died on him
I vag'ed it and came up with:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 037 906 259 D
Component and/or Version: MOTRONIC M5.9 HS V09
Software Coding: 00000
Work Shop Code: WSC 00066
3 Faults Found:
17884 - EVAP Leak Detection Pump: Insufficient Vacuum
P1476 - 35-00 - -
00668 - Supply Voltage Terminal 30
07-10 - Signal to Low - Intermittent
17988 - Throttle Actuator (Bank 1): Malfunction
P1580 - 35-00 - -
Anyone have any ideas on what went wrong? It died graduaally and I'm thinking it might be the alternator but any input is appreciated!
Old Feb 28, 2007 | 02:43 PM
2k S4's Avatar
Default RE: My buddy's golf- died on him
http://www.ross-tech.com/vag-com/cars/vwmkIV.html
Have you tested the voltage at the battery? With the car running & off. WHAT IS IT?
My guess is there is a ground problem. The car died, due to the throttle body not functioning.
Old Feb 28, 2007 | 10:20 PM
wood_e's Avatar
I measured the voltage at the battery. 11.6 volts with the car off, 10.5 volts with the engine running - there's an issue there!
Old Feb 28, 2007 | 10:46 PM
2k S4's Avatar
ORIGINAL: wood_e
The battery is weak, unloaded voltage should be over 12v, usually it's around 12.6. It should be around 14.4 with the car running.
So yes, I would say the alt is not working properly.
certifiedprofile
May 22, 2014 08:37 PM
NuYorka103185
Dec 4, 2009 12:53 PM
JP A4
Dec 16, 2006 02:15 AM
