NEED HELP PLEASEEEE A4 HURT BAD!
Old May 1, 2007 | 04:28 PM
euroracersa4's Avatar
Default NEED HELP PLEASEEEE A4 HURT BAD!
1999.5, 1.8t, 5speed, front wheel drive, 130,000miles
hey Im Johnny. I was driving on the high way going 65mph. I was just cruzing. Then all a suddin Zummmmm the quickly lost all power, eventually leaving me on the side of the road. the car would not start up again. I had to get it towed. now I get the car home and try to start it again and it wont. It makes a sound like this "zizzzzzzz" and my buddy was looking under the hood and he said that everything was spinning. fan, belts, ext.. but the car wont even give a start or even an attempt. I took out the spark plugs and the first plug looked like it had been dipped in oil. all the other pluggs were ok. I took off the valve cover and replaced the valve cover gasket and the spark plugs, and their gasket as well...so now the car has spark (I checked and got shocked I know). I have no clue was the heck is wrong it still wont try to start. I never would hope for anyone to have this problem! but I hope that someone that has had it will reply to me and tell me what they think.......PLEASE HELP ME!!!! If it helps any the oil light came on for a quick sec right when the power loss occured. I checked the oil and everything is good....still no start....
Old May 1, 2007 | 05:02 PM
qttrcoupe's Avatar
Default RE: NEED HELP PLEASEEEE A4 HURT BAD!
Its not a timing belt is it? I personally have never had one go but.... its a possibility
Old May 1, 2007 | 06:31 PM
hey I dont know but Im starting to be really sceared...someone told me my engine might have blowen! I dident have any smoke and no really loud noise or anything like that, just lost power....I hope its the timing belt and nothing super horribale, I will check the belt and let you know thanks for the reply....I am aslo gonna get a scanner thing to read the codes I will post those soon too.
Old May 1, 2007 | 06:57 PM
qttrcoupe's Avatar
The problem is if it was a t-belt there could be more damage than visible... Most likely there is if it was a t-belt. wasit still running when you pulled off the road?
Old May 1, 2007 | 08:25 PM
no it wasnt running anymore it stalled out.....It was still in gear and I rolled off the highway.
Old May 1, 2007 | 10:32 PM
!!!!! P1338 !!!! Macufacter Control igniction or misfire! wow...how do I fix that?
Old May 2, 2007 | 03:04 PM
LampyB's Avatar
run a search for the P1338 code in this forum. you should find plenty of help there. once you narrow it down on what the fix is, look up how to do that and see if it can be done yourself. if not, you're going to need to take it to a mechanic, try to stay away from the stealerships...they'll rob you blind.
LampyB.
Old May 2, 2007 | 09:28 PM
CRAZYHAWK's Avatar
Check the wire to the camshaft position sensor.
Old May 3, 2007 | 05:30 PM
GOT IT!!!! the timing belt was on but cracked so it sliped some teeth!!! so now I took it to a shop and they said that they would take care of all of that for me! its expensive but I cant wait to have my baby back so its worth it! it cost $1300 dollars, and they are gonna remove the block and check the cylinders, and also replace the piston and rings, they said the engine might need to be boarded up and thats gonna be fine with me, cause they said that they are gonna pay for that part,(even thought I know I am paying for that 1300).....but its gonna be dfaster when it comes back and they said that They will also flash the computer and put a chip in it.... WOW I cant wait to get it back!
[IMG]local://upfiles/34704/9A9069E527F149C3A921C56C0BBD5CC1.jpg[/IMG]
Old May 3, 2007 | 05:35 PM
techbod's Avatar
good luck with you Mate
northwest b5
Jan 6, 2013 05:49 PM
roll4ever
Dec 26, 2008 01:49 PM
GDET09
Apr 19, 2008 09:07 PM
Porschekid
Apr 5, 2008 05:00 PM
