Oil in Water
Old Apr 20, 2008 | 03:35 AM
norrol's Avatar
Default Oil in Water
My 1998 A4 2.4 with 60000 ks has developed a problem with oil appearing in the expansion bottle.
What tests should be carried out to determine where this oil may be comming from and in what order should these tests be carried out in
Ther compression test done before I purchased the car 5000 ks ago had all cylinders showing good compressions all reading 90
is this oil a sign that perhaps I have a cylinder gasket or head problem.
Thanks for any help offered
Ron
Old Apr 20, 2008 | 12:18 PM
zippy_gg's Avatar
Default RE: Oil in Water
Typically when you have a bad head gasket or a warped cylinder head you will burn water resulting in a white puffy cloud out of the exhaist pipes. That is because water finds its way inside the engine. I have never seen the other way around, oil in the water.
Check your oil and see if it is emulsifying, and indication that you indeed have a head gasket problem. If you do, don't drive the car. Water is a very poor lubricant and you will seriously dammage the engine.
krystallbluea4
Jan 3, 2009 01:44 PM
fcamargo6thave
Oct 12, 2007 07:22 PM
readimag
Sep 4, 2007 12:11 AM
ncsurmy
Dec 4, 2006 08:00 PM
