Parking brake malfunction/ABS/Traction Control Problems
Old Jun 25, 2014 | 07:40 PM
Airmantony's Avatar
Default Parking brake malfunction/ABS/Traction Control Problems
Hello,
I have a 2005 Audi A6. It has the following problems: Parking brake, Traction Control, and ABS malfunctions. I brought it to the dealership and they diagnosed it as the following:
"Found fault for G201 Pressure Switch in ABS Hydraulic Unit. Checked values with MVB's and found switch is showing a default value of -40 Bar and does not respond. Switch is internal to unit, rec. replace ABS Unit Recommend replacement of ABS Control Module $2,700" (yikes!!)
Any suggestions? Is there an electronic solution to this without the replacement? Or is there somewhere I could send the ABS module to instead of getting a brand new one?
Thank you so much, I really appreciate your help!
Tony
Old Jun 26, 2014 | 08:51 PM
jim.piazza's Avatar
I have the same Audi A6 - same issue. When I put a code reader on the car nothing came up. Could it be the code reader isn't programmed for an Audi?
Thanks
Jim
Old Jun 26, 2014 | 10:25 PM
Airmantony's Avatar
Hi Jim,
Thank you for your reply. I'm not sure if the computer was calibrated or not, I just brought it into the shop and thats what they said. Is your car doing that annoying beep every time you go over 10 mph? Did you have any luck fixing it? Or at the very least shutting off that obnoxious sound?
Thank you,
Tony
Old Jun 27, 2014 | 10:21 AM
AudiRobA6's Avatar
Default Try this..
Try looking at your multifunctional switch to your transmission. I just had mine go out and it has the same symptoms as yours the it stopped completely. I'm at the shop now having it replaced.
Old Jun 28, 2014 | 09:27 AM
jim.piazza's Avatar
Do you know what the part is called? Where is it located?
Old Feb 13, 2020 | 07:40 PM
graham baker's Avatar
Any luck with this?
Old Mar 27, 2020 | 03:02 PM
Mrmonger's Avatar
Hello
pls can anyone help with this please.
I have Audi a6 2.4l v6 engine 2005 model my car is not moving well if I engage it in drive or reverse is making noise and slow to move but speed on a
Normal ground but any hill it slow. And on the dashboard is showing EPs faulty and if engage parking break is beeping I have change the transmission oil with 6letre is still moving smooth
danno6
Nov 29, 2020 02:36 PM
2005audiA6
Dec 8, 2016 04:00 PM
smacky77
May 9, 2015 02:59 PM
bmvalves
Nov 11, 2014 09:13 AM
jonny17
Mar 24, 2009 03:50 PM
