power gains from turning up the boost
Old Nov 25, 2005 | 11:37 PM
richard7285's Avatar
Default power gains from turning up the boost
has anyone on here used a boost controller to turn their boost up? i'm gettting one soon and want to know how much i can turn it up safely and how much power i will achieve. thanks. i have a 2000 tt 1.8t non-quattro btw.
Old Nov 29, 2005 | 05:29 AM
Default RE: power gains from turning up the boost
so 19 ppl view the post and dont reply? good stuff
Old Nov 29, 2005 | 08:22 PM
34 ppl hav enow viewed this thread and have posted nothing! wow what a great site filled with input you guys have. i guess i'll go check out another 1.8t forum where people actually know about and modify the cars they own[:'(]
Old Nov 29, 2005 | 08:26 PM
techbod's Avatar
wow that's a lot of people looked, your car needs to be on a rolling road to get the best out of it
Old Nov 29, 2005 | 09:03 PM
trailboss's Avatar
STFA!!!
This is asked by about every noob. Search "CHIP". MBC are pointless, they don't add X amount of fuel for the X amount of boost you would be running so you will run lean and soon blow an engine because you didn't wann for out the extra dough for a chip.
Old Nov 29, 2005 | 09:15 PM
trailboss's Avatar
ORIGINAL: richard7285
Well if you post something on audiworld like this you will probablly be flammed, audizine you might get away with less flamming. Search before you post b/c 8 times out of 10 its more than likely been covered in the archives.
Old Dec 1, 2005 | 01:55 AM
ORIGINAL: trailboss
STFA!!!
thanks for your response i will be upgrading my fuel managment as well but i was wondering how much boost the stock turbo is capable of. getting a chip is not a problem i just prefer to not run high boost all the time so a boost controller (dual stage turbo xs) is what i have. i'm reflashing my ecu as well but before i dropped the extra cash i wanted to see if it was worth it
Old Dec 1, 2005 | 03:44 AM
trailboss's Avatar
Well running some type of chip and having an MBC to override the chip is sometimes good, gets rid of boost spikes and flatens it out. The down fall to it which it seems like you are planning to is lowering the boost when the chip is tunned for ~1.1 bar, so you are getting alot of extra fuel because the boost is turned down but the ecu is still thinking you are getting 1.1 bar of boost. In other words you will run rich, which is better than lean but too rich can cause problems too. If you are looking to have something with different boost levels look into APR's porgrams.
As far as a safe boost amount most chips run 1.1 bar which is ~17psi which is a safe boost amount considering you you allow for proper warm up and cool down of the turbo. There are plenty of people out there with over 40k chipped miles on the stock turbo. Sure you can run more boost but considering the k03 cant hold 17 past 5k its kinda pointless.
cruisina490
Sep 4, 2008 01:15 PM
fobyulous
Feb 19, 2007 12:43 AM
Deb38
Dec 14, 2006 04:52 PM
16w/A4
Mar 14, 2006 01:38 PM
02TTs
Mar 3, 2006 07:00 PM
