S4 FUEL INJECTOR QUESTON
Old Dec 4, 2006 | 09:24 PM
HG's Avatar
HG
Default S4 FUEL INJECTOR QUESTON
So my mechanic says my Injectors are going out. Audi has them for about $105 each. What are my other options? Could I run larger injectors at a lower dutty cycle? Any and all help will be appreciated.... Hector
Old Dec 5, 2006 | 01:39 PM
rayveedub's Avatar
Default RE: S4 FUEL INJECTOR QUESTON
105 isnt a bad price my cost is 94 bucks for oem. i would go that route. But yes you can regulate a larger injector, but that is pointless. only use larger injectors for an upgrade and that is after you get a pump and regulator to supply them.
Old Dec 5, 2006 | 02:36 PM
HG's Avatar
HG
Yeah, I think stock is the way to go for now. Just for conversation: If I did go a bit bigger injector, pump and regulator. Could I then run a split shot of nitrous (50/50hp)? Or would I need more fuel? thanx rayveedub....
Old Dec 6, 2006 | 12:50 AM
dankhound's Avatar
If your going to run nitrous i would recomend a wet kit that supplys both fuel and nitrous. Its far safer than gambling on the injectors to supply the extra fuel you will need, which is the case in a dry kit.
Old Dec 6, 2006 | 01:30 PM
rayveedub's Avatar
s4 has big injectors as is, all i would do is the pump and adjustable FPR. A 50 shot direct port wont be that bad. for best reliability i would definately look into a fogger system, this avoids concentration in certain areas. If you wanna get really clever do the 7th injector on a switch, but that is over the top. Also it wouldnt hurt to use a program like lemmiwinks and turn back timing a few degrees. the key is run rich. rich is safe.
Old Dec 6, 2006 | 02:42 PM
HG's Avatar
HG
That game me a lot to think about. I appreciate you guys taking time to answer my question. I will keep you guys posted.
nexusgroove
Jan 5, 2011 12:10 PM
rmac.cab
Aug 6, 2009 10:50 PM
99A6Quattro
Feb 14, 2009 12:00 PM
TTsteve
Apr 7, 2006 07:44 PM
TTsteve
Apr 5, 2006 02:21 AM
