S4 turns off and wont start - intermintant
Old Jan 5, 2008 | 03:53 PM
syxxty's Avatar
Default S4 turns off and wont start - intermintant
Hi all. I have posted this in the S Line forum :https://www.audiforums.com/m_711270/tm.htm. I thought my problem was restricted to my B5 S4 but the code I just pulled makes me think anyone could help.
Summary of Issue: Car will just shut off while driving and will not start for a period of time (which has ranged from a few seconds to over 30 mins). When this happens there is a clicking under my dash which is the Fuel Pump relay. I have replaced this relay and it seemed to help but then it shut off again. The Vag code that just appeared is:
18011 - Internal Control Module: Failed Self-Test
P1603 - 35-10 - - - Intermittent
Has anyone seen this? Is my ECU bad? Thanks for any help.
Old Jan 5, 2008 | 07:00 PM
auditech79's Avatar
Default RE: S4 turns off and wont start - intermintant
Well its a internal control module malfunction which is never good, if it were a check sum error i would say its your ECM right off the bat.
Since you don't have any other fault codes there is little it could be besides the ECM un-fortunately.
Old Jan 6, 2008 | 09:08 PM
tHe kNiGHt FaLL's Avatar
you don't have a performance re-flash or anything do you...?
cause there is no way to test the control module itself...
Old Jan 7, 2008 | 10:47 AM
syxxty's Avatar
No flash or chip in my ECU. It is bone stock. I am searching for new/used (stock or chipped!) ECU to rule out the ECU. I am hoping this will fix it.
joeywebb
Feb 5, 2013 12:01 PM
nickk75
Feb 13, 2012 01:26 PM
millenia
Mar 31, 2009 04:31 PM
BryraTodds
Mar 30, 2009 04:12 PM
stranger706
Nov 29, 2007 08:37 PM
