Scraping Brake Pad Noise....
We're semi retarded 'round tehse parts. Which atually means that we're as dumb as a Truck
Yes, that's what he's sayning. Sometimes you hafta kinda tryN figR out what we mean, from what we say. Sometimes not. This/that isn't a NOT time[&:]
Do you knwo if they lubed the slides when they put everything back together?
Are you SURE it's the brakes?
my apolls I thought you would understand
that's exactly what I meant but other things could be causing it like edges on the rotors "as the pads wares in they cut into the rotor leaving build up on the outer edges thus causing noises, next is the emergency break sticking on slightly then there is the pistons sticking/cheap break pads/dust covers "quite" a list so a good service to the breaks might be a wise thing
